racing 3.5 altima
All things Altima Coupe.
jstinkybear1
I have a 3.5 6speed , i never had a fwd car before . does anyone Know what rpm to drop it at???? I do at 3000rpm with trac on but i spinn too much??
One Crazy Max
Car: 2007 Nissan Altima 3.5SE 6MT
jstinkybear1 wrote:I have a 3.5 6speed , i never had a fwd car before . does anyone Know what rpm to drop it at???? I do at 3000rpm with trac on but i spinn too much??
you obviously are not supposed to drop the clutch with a car that has so much torque.
what you should do is slip the clutch in at around 2700rpm, hold the throttle in that position, let the car get rolling a for a little bit, and then just dump the clutch all the way.
it takes practice with this car, but you should get it soon enough.
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
Good Call, that is a good way to launch the 3.5. Now on my ol Z its more around 4K-4.3K, of course VDC off...but its RWD and only 274ft-lbs crank
