dldjros69 wrote:
im gonna need an explanation of what these dooooo?
But im soldddddd.
-adjustable Camber / toe arms
correct toe/ camber setting from lowering a vehicle. Are also completely adjustable to dial in your own settings for track use. Will use polyurethane bushings instead of the OEM rubber type, which will resist deflection and provide for greater handling. Although admitted the A/C is still pretty new and the oem rubber wont be that worn just yet, but it will still be an improvement
-under body chassis bracing
Stiffens the chassis to resist flex while cornering, mush like a strut bar does.
-Traction rods
Attach to the frame and control arm to stop the control arms from deflecting under hard launch situations. The deflection caused creates wheel hop in a front wheel drive car which is very bad for the car and your times at the track. Similar to ladder bars used on RWD cars, but alot simpler to install and not as intrusive to ground clearances on street cars.
-intake
self explanitory
-custom Radiator shroud
This is a carbon one in the pic http://image.turbomagazine.com...d.jpg
but it basically surrounds the rad on top to give the car a "finished" look and also help make sure you don't touch any hot hoses. but mostly it's a dress up item.
Modified by Racingline at 12:15 PM 9/25/2009
