I have been running 110 plus for a year still no bad injectors. Your O2 sensors will not like the fuel at all. SO if you are running stock O2's you will need to replace those soon.jerdog1 wrote:Quick lead to burned up injectors! I ran a post about octane boost and got the same answer;no it is not a good idea!
Thanks for the info guys! I wasnt really sure how accurate that info was...appears it wasnt at all. Would you recommend like an "Octane Boost" type of fuel treatment or the "Injector Cleaner" type? Or does it matter? Sorry for the dumb questions...but I apprecaite ya'lls help!MinisterofDOOM wrote:I doubt you'll see any good or bad from it. If you want to clean things up, run a can of Techron or BG44K or similar fuel system treatment through the car.
I'm not sure where the logic behind that comes from, as premium is NOT better quality or purity-wise, it simply has better knock-resistance. Higher octane has no relation to burning deposits at all.
Race gas is expensive and fuel treatments aren't.
Well seeing i dont have a cat,res or muff i think im safe lol. Plus if they really stopped us up here running leaded fuel. Most of us would be fined. I run race fuel in everything i own.mtcookson wrote:If the gas you're using is toasting O2 sensors you're probably using leaded gas, which is a bad idea, more so if you still have a catalytic converter on your car. I definitely would not run leaded racing fuel with a standard setup like that as it will cause issues. Plus, if I remember correctly, if you're caught running leaded fuel in a street car you can be fined up to $25,000. (which I think is absolute b.s. really)
??? The octane has nothing to do with the tuning... it doesn't change the tuning. If your car runs rich on 87 it will run just as rich on 110.2K2WhiteMaxSE wrote:It doesnt have to be leaded fuel to fry a cat or an O2 sensor...if its a high enough octaine and your car is not tuned for it then it will be running very rich and could have a lot of unburnt fuel passing through the O2s and into the cat and will screw them both up...
you're a rich man, i'm going to fill up today because premium is down to $3.09kzoosho wrote:
