KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sat Sep 23, 2006 7:09 am
I am coming to the conclusion that plug reading on a turbo car is a moot point. The operation conditions change so drastically, that, even when you operate to a given load / rpm, then shut the engine down, the plugs still don't tell the full story.
I'm considering purchasing a single plug from a company I found that offers plugs with built in pressure transducers.
To read the exact cylinder pressure accurately, you'd need some VERY expensive data processing equipment. However, to effectively use the plug as a diagnostic/tuning tool, you could easily use some lesser grade processing to establish a waveform that shows a pressure curve. Who cares if it's accurate, in terms of cylinder pressure? You just need a pressure curve to inspect for signs of cylinder pressure spikes.
I'll update further on this as I go along.
