RAbbleGrabbleHrrrmmphh! ECU is dead.
KATwo40
Car: 1993 240sx KA-T
Well, this is pretty annoying. Recently, my MAF went out. What did it take with it?
The ECU!
Symptom:
Ignition timing at idle won't adjust (stuck at TDC with the dizzy cranked all the way).Vehicle won't start with TPS unplugged (goes FULL rich)I can't drive my car.
Test findings:
Key on, engine off, TPS connected = 0.4v on the return circuit.Key on, engine off, TPS disconnected = 2.3v on the return circuit (which should be 0.0v)!
Checked all the engine and ECU grounds, tested with EVERYTHING disconnected in the engine bay (O2, injectors, coil, ignitor, MAF, TPS, IACV, CTS, Temp sending unit, Distributor) and got same results...2.3v on the return circuit.
So, there's something that has started backfeeding into that circuit inside the ECU.
I'm grumpy.
Florida240sx
Don't know...I'm having wiring problems as well. So where is the source coming from?Relay box?
KATwo40
UPDATE...According to deviousKA, those voltages are normal. LOL I guess I'm a tool.
However, we're still trying to figure out why I can't adjust timing and why the ECU fires off the injectors like mad with the TPS disconnected.
Florida240sx
Could it be a faulty board?
KATwo40
If anyone needs me, I'll be in the other room...hitting myself in the face.
The dizzy was off one tooth. Car runs great and I've been working the tune.
hehe.
wild_maxx
Car: 90 TT pearl yellow z32
haha cool deal. I need to meet up with gabe and get the 2 step setup on my ecu!
WDRacing
KATwo40 wrote:If anyone needs me, I'll be in the other room...hitting myself in the face.
hehe.
DUMBASS
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
my bet would be on a capacitor.. take a look at em their pretty straightforward to replace if you know how to solder
because if you getting voltage somewhere where it should be 0 then i think a capacitor is shorted..
Marko
TheOne
Car: 93 240sx FB
i would think the car wouldn't start at all if the ecu was bad.........
but eitherway ya fixed the problem.....
KATwo40
Yup, it's fixed. And it's quite fun @ 13psi LOL
wild_maxx
awesome! Now lest seee some vids of that beast.
