R52 oil?
Skelshy
Car: 2018 Pathfinder SV AWD
I have a new (to me) 2018 Pathfinder. Manual specifies 6 mo/5k miles interval, in one section it says it needs to be API certified and appropriate for your climate. In another section it says Genuine “NISSAN Motor Oil 0W-20 SN” is recommended. I am in the Pacific NW (moderate climate, not much snow)
Goodyear auto care said the vehicle needed 0w30 and they only had that in synthetic ... then they went into an upsell of their premium filters. I'm not that cost sensitive, but it just didn't sound like good advice. If I am going to follow the manufacturer's schedule, which I like doing, that's probably overkill. I've driven more than a year on synthetic oils on vehicles that had an oil life indicator.
Looks like 5w30 should totally do for this climate, should I just ask them to put in 5w30 dino oil?
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
In a mild climate 0-30 will be fine if 0-20 is the spec. You might lose .01MPG. Synthetic is better, but not essential, especially if it wasn't called for it originally.
Oil change places are notorious for not knowing what the spec is, even if the car has it printed in the engine compartment. And there are a bunch of grades and they probably only have about 3 that come out of the gun and another couple in bottles. So they have a baseline default and probably suggest it for almost everything. Regardless, 0-30 won't hurt anything, nor will 5-30 which might result in .03 less MPG. Tight clearances allow thin oil and with tight clearances MPG standards dictate it from a Mfr standpoint. The oil change place either wants to upsell you or use what comes out of the gun.
JayArras
Car: 2013 Pathfinder SL Premium (traded in)
2023 Pathfinder Platinum AWD
The oil change process on the R52 is not that difficult. Why not do it yourself?
BTW, I use full-synthetic on my 2013 SL and a 7500 mile change interval.
Skelshy
Mike W. wrote:
Wed Sep 16, 2020 10:38 am
Great post, thank you!
Skelshy
JayArras wrote:
Wed Sep 16, 2020 10:42 am
https://youtu.be/JgGJgHEq1TE
Thanks. I have done it in the past, when I had a garage to keep oily things stored :) Not currently very attractive with no garage. Also, oil change and tire rotation for $50 isn't unreasonable, plus any other issues they might find. I just don't like booking a $50 appointment and then it's a $100 appointment from the start.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
How to Choose the Right Oil Filter for Your Car (it's a rather lengthy article)
PalmerWMD
Car: 2004 350Z
That same engine is recommended by Nissan Europe as 5w-40 year around.
Like I been saying for years the EPA testing cycle for MPGs is biased towards cold running.
This is why in the USA all these really thin oils are recommended that are not recommended anywhere else.
PS: I always upgrade to the better filter whenever possible.
Its not about the filtration or the capacity..
Low end filters are vulnerable to construction failures..A filter that had its internal crushed or decomposed will send all sorts of cardboard thru your engine.
Usually not immediately deadly but definitely not good.
Skelshy
Put in 0w20 synthetic at another shop. Will keep at 5k intervals for the remaining balance on the powertrain warranty, then probably do 7500 mile intervals.
Mike W.
2002 BMW 525it
PalmerWMD wrote:
Thu Sep 17, 2020 7:42 am
Interesting, I didn't know that. I knew it had to do with EPA MPG, but wasn't aware the cycle was biased towards cold running.
Some years back now I heard about some cheap filters exploding under cold, high pressure conditions. IIRC it was Mitsubishi cars.
