R51 roar on start up
brickbox
Car: 2011 Nissan Pathfinder 4x4
So over the past year, my R51 Pathfinder makes a roaring sound (not grinding or screeching, just a roar) for the first couple of seconds on cold startup and goes away.
I don’t see anything obviously broken or worn out. Serpentine belt is in good condition and feel taut using finger push test.
Any thoughts what this could be?
I'd suspect a belt tensioner going bad or a failing fan clutch first.
brickbox
Thanks. I think it’s the fan clutch since it roars like a plane engine. There’s no belt squeak or squeal
I am able to turn the fan on a cold engine about 1.5 turns despite the fact I can’t get good leverage. Is that normal or too loose?
That's too loose. Common failure, I just replaced mine on my D21.
brickbox
Thanks AZHitman.
Out of curiosity, did you change yours with a Nissan OEM one or do aftermarket clutches suffice? I’m debating getting one from AM Autoparts because they seem have a 10 years warranty.
I used aftermarket.
brickbox
Great! Appreciate the quick response.
