Lol, you can't build a Rolls for a nickel. DeLorean tried, and look where it got him. Now, if he could've really built them with Flux Capacitors....
Lol fair enough! In other news, the bottom bolt on the drivers side came off with a fair bit of fighting, but it’s off nonetheless. I was able to get the nut out on the top bolt as well. But…..VStar650CL wrote: ↑Mon Jun 28, 2021 1:08 pmLol, you can't build a Rolls for a nickel. DeLorean tried, and look where it got him. Now, if he could've really built them with Flux Capacitors....![]()
Yep, just whacking it off should be fine for that.
That's generally a good rule to follow or just torque to the low end of the torque spec range. Since the FSM doesn't give a range in this case, dropping the the torque to 97 ft-lb is still good-n-tight.
ha, thanks! I think I would be lucky to turn any of the suspension bolts front or back with the Craftsman breaker bar I have. But, the car is back on the ground and a quick test drive revealed no sounds. Bonus, the cheap FCS shocks seem to handle the ruts and RR crossings without causing it to bottom out any more.AZhitman wrote: ↑Thu Jul 01, 2021 9:06 amThat gives me the heebie-jeebies just looking at it.
If I go to inspect a car to buy, if I can't turn a control arm bolt with a 1/2" drive 2' ratchet, I walk away.
You're a brave soul, brother. Glad you're making headway. If I lived there, I'd be hosing down my entire undercarriage with FluidFilm every weekend.
Totally agree. I coated the bolts in the grey bottle antiseize and also applied a thin coating on the inside of the shock sleeve as well.The Grand Pooh-Bah wrote: ↑Thu Jul 01, 2021 10:00 pmI just did my control arms and shocks in the rear. When I put everything back together I used WD-40 Dry Lube on all my bolts. I like to think about the long term, and making someone's job easier than what I went through.
