Dose any one know how to get into the climate control settings, to enable the climate control to go from the lowest setting of 16 degrees to LOW, like most other cars on the market.
The reason I ask is because, most cars with climate control that can go to LOW, or even older cars with the blue and red lines (for temperature control), when set on the lowest setting would normally go down to 4-6 degrees supply air at the vent, which is when the compressor cuts out, and then cut's back in at 10-12 degrees
With the set point at 16 degrees, mine will only achieve a minimum of 12 degrees supply air, and being a wagon and after sitting in the sun all day in Brisbane, the car gets dam hot. So having the A/C go to a lower setting would be so much more comfortable.
The mechanical and refrigeration function and cycle of the A/C system is not at fault this time, although I wish it was as it would be a quick fix for my self.
I am expecting this to be some kind lower emissions setting they have introduced, like the green wire mod and the EGR valve. To prevent to compressor from running longer, therefore using less fuel burning less emissions etc.
I have also read through the manual in this link, but I do not think that the procedure on pages 24 & 25 can be carried out on my R51 ST-L, as the radio and climate control functions are different.
http://www.nicoclub.com/FSM/Pathfinder/ ... er/HAC.pdf
I am hoping that it is some kind of procedure like, Turn the ignition to the on position, turn this knob and hold this in etc.
