The only exception would be my window/door lock control panels, on both the driver and passenger sides. They're both still rockin' the stock plain lights. So is my defroster switch, for that matter. Has anyone switched out those lights for LED's? Any recommendations for size? After spending the good part of an evening doing my AC unit, I'd rather go with ready-made, off-the-shelf items rather than futz around with resistors again. I'm guessing the clearance in there is similar to the (lack of) clearance in the defroster switch.
Speaking of, I've read a thread somewhere (either here or on nissanpath) about exchanging the defroster bulb for a LED and resistor setup, similar to my climate control mod, but I found with the LED I had from Radio Shack plus the resistor there was just not enough clearance, so I've left it stock.
Lastly, does anyone know if the mirror control switch is supposed to be illuminated? I'd rather not go through yanking it out of the dash to look if there's not a bulb in there...
