Blindaviator »
https://forums.nicoclub.com/blindaviator-u272878.html
Tue Jun 13, 2017 7:06 pm
So a while back I posted about my 2001 R50...
Since I purchased the Pathfinder back in February I have had an issue with it pushing coolant out into the overflow. Running around town it has no issues but once I hit the highway is where it starts to have issues. If I run at least 10-15 miles it will push enough coolant out to fill the over flow tank. If I run the A/C it is a LOT worse. Once it sits overnight it will usually pull the coolant back into the system filling it back up. At no time has the temp gauge ever moved above it's normal level.
Since then I have replaced:
Radiator Cap
Water Control Valve
Thermostat
Radiator
Water Pump
Fan Clutch
I have used the chemical test for unburnt hydrocarbons in the coolant and it was negative. I also purchased a pressure tester and the system will hold 14 lbs of pressure for 20 minutes without dropping (cold and hot engine.)
I'm still racking my brain on what is causing the issue. I have tested and replaced every thing that may be causing issues.
Any thoughts??
