Mike W. wrote: ↑Wed Oct 06, 2021 10:09 amAre the brakes adjusted correctly? Can you bleed the rear brakes? Assuming not a couple of things come to mind, brake hoses can fail by expanding internally and not allowing fluid to pass thru. So a bad hose is a possibility. And ABS can prevent bleeding. Sometimes you have to actuate the valves electrically inside the ABS unit, but sometimes you can get fluid movement by getting one side of the vehicle on pavement, the other on dirt and hitting the brakes hard. That will cause the ABS to activate and possibly allow fluid thru.
Our inspection here in NZ is 6 monthly for all trucks trailers. And all cars pre 2000 is 6 monthly and yearly 2000+ its a right pain/money making schememdmellott wrote: ↑Fri Oct 08, 2021 8:06 amGot it. Roller brake testing is not a routine inspection requirement for vehicles in the USA, as it is in Europe and Australia, except for heavy commercial trucks and buses. I would venture to guess that many vehicles in the USA would not be allowed on the road if roller brake testing was performed during our periodic registration inspections every 2 to 4 years.
I wish you the best of luck tracking down the faulty component. Do you think it could perhaps be worn out brake drums or oil contaminated brake shoes?
Wow, that's extreme. Light trucks like the R50, not just heavy trucks like we often refer to as 18 wheelers? Wow.Kieran the mechanic wrote: ↑Fri Oct 08, 2021 6:36 pm
