nobb »
https://forums.nicoclub.com/nobb-u175225.html
Mon Feb 21, 2011 11:11 pm
I have a 2001 Nissan Pathfinder (R50) and I was attempting to take off my front axle to inspect the CV boot due to minor cracking and also because the boot required tightening since the edges were leaking.
When I put everything back together, I was tightening the 6 bolts onto the wheel bearing lock nut (I think that's what the big metal disk which the 6 bolts screw onto is called?) and two of the bolts sheared right off. Not sure why it happened so easily since I was using a torque wrench and was nowhere near the 78 Nm torque spec yet. So my first question is...how crucial are these bolts? They seem mostly for centering the wheel axle on the bearing and to transfer the force from the axle to the wheel. Does the entire wheel hub need to be replaced?
Question 2: How important is preloading the bearings and how do you do it? I noticed the service manual recommends preloading the bearings after disassembling the axle or changing out the bearings but all that it is is a tightening of the bolts around the wheel bearing lock nut/wheel hub. Also, the steps become very complicated and also seems to reference the use of specialty tools for the preloading. Is it sufficient to just tighten all the bolts to the same torque spec and call it a day?
Thoughts? Thanks.
