m0nkeyprince »
https://forums.nicoclub.com/m0nkeyprince-u164086.html
Sun Feb 12, 2012 4:53 pm
you just need to directly swap em. Also the kit probably comes with extra long studs to replace the stock ones but some people dont swap em as they are a pain to do.
hammer/pry out your stock hub cap,take our the retaining ring, unbolt and remove the "always engaged" hub (there are 6 nuts i think), put in the warn hub, bolt it down, put in the retaining ring ( i reused mine). Youre done! a couple members here have done it without even removing their wheel, but i find that it helps.
