So who's the man that knows his s*** on the td27eti or qd32?
1996 r50 td27eti auto 4x4, flyby wire injector pump.
Running a 14pin nissan plug
Got fault codes 11 & 47
11 crank angle sensor.
47 TDC sensor. Crank sensor
Picking they are the same sensor. On front of engine just above crank pully.
Had #47 1st truck was running and light came on and went off and came back on and went off.
Then had #11 when trying to start, would not start. After a lot of attempts to start I tried, foot hard up it a few cranks and it started.
So picking it codes 47 when engine is running and 11 with it won't start ???
Cheers
