R50 Can't remove timing belt upper cover - A/C pipe blocking
pwachon
Car: 1998 Pathfinder SE 4x4 R50
Folks,
Title says all - the aluminum air conditioning pipe that runs across the top of the timing belt cover prevents me from removing it.
Any advice?
Thanks,
PIerre.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Looks like unbolting and moving the compressor is the solution. help-ac-line-in-way-of-top-timing-cover-t572068.html
pwachon
Should have replied earlier but yes, that did it (in addition to unplugging an electrical harness right above the compressor so it would swing far enough forward to enable the removal of the cover).
Thanks for the tip, saved me a bunch of time.
