I have a big trouble last 2 years on my 1998 3.3 v6 manuel 5spd 4x4 transmission pathfinder. Pathy sometimes good but sometimes misfired only 1500-2100 rpm on the way in any gear.(neutral gear or idle position no problem this hesitation only when acceleration/on the load)
My car accelerates at 1000-1400 rpm without hesitation. It is still unhesitating between 2200-6000 rpm.
I tried the followings but I can't figure it out for 2 years,i think i am gonna burn it.
-new spark plugs(i tried 3 set for NGK BKR6E-11-BKR5ES-11 and Platinium NGK 7090) There is no obvious defect in the spark plugs when i removed.
-new spark cables 3 set.
-All pistons have ignition, because I tried pulling the plug cables one by one.
-new hitachi maf sensor and i tried my friends car mass air flow sensor. Values good 4.8 g/s idle and 14.5 g/s 2500 rpm
-changed before a new coil-new chamshaft position sensor (RSB56 ignition control module),rotor, cap and finaly i bought 2 new distributor during this time. Advance timing checked and adjusted with timing gun 13-15-17 btdc over and over.(i know timing adjust procedure, car always in operating temperature, tps bottom/ brown socket unplugged mode and the pulley mark is in the 4th notch from the left.)
-new throttle position sensor and i tried my friends car working tps and adjustments on the nissan service manual procedure with 0,3mm-0,4 mm feeler gauge or 0,48v trick. I tried throttle body cleaning and checked all spring bolts possible cracks connections
-I checked all grounds,tried new cables.
-I tried egr delete (I canceled the egr with sheet metal and all hoses blinded)
-I tried 2 different fuel pumps. Change it fuses and relays. I changed fuel filter 2 times.
-I tried 1 new map sensor and tried myfriends car sensor.
-I tested at 2 different times all injectors in the test machine. They dont leak or dont have bad spraying.
-I tried other fuel alternatives and i connected liquid petrol gas system. You know this have 6 new lpg injectors,tank,ecu and injector harness. But no difference.
-I checked 3 times timing marks from the camshaft and crankshaft sprockets. (40 teeth and 43 teeth verified on the belt from service manual)
-I tried another timing tensioner.
-I checked it charge unit. Normal voltage 12.2 v-car working voltage 13.7-14 v
-I tried new battery.
-I changed 2 times crankshaft sensor on the transmission bell
-I changed knock sensor
-I tried another air filter and air temperature sensor
-I checked fuel preassure regulator. Vacuum hose connected 34 psi and disconnected 42 psi its good. And no fuel leaks or cracks on the vacuum hose.
-I changed up 2 oxgen sensors.
-I checked evap leaks from the hoses blowing a smoke.
-I changed PCV and hoses
-I changed Engine Coolant Temperature Sensor
-Checked 2 cats its always empty.
-I tried good working car ECU(its same 1998) and i found same model ecu harness i try it 500 miles but no different.(You know the ecu harness connects to almost all sensors and distributors, this isnt bad connector or cable problem i have comfirmed)
-I tried new injector wiring harness.
-I checked brake booster for vacuum leaks
-I checked all vacuum hoses i tried spraying carburator cleaner all important points. And i try smoke machine on the intake manifold.
-İdle stable 800-850 rpm but, i changed iacv and fic selenoid. I tried it blinde a idle control valve hoses.(for possible vacuum leaks but dont solved)
-I changed oil preassure sensor.
-I tried all sensors unplugged mode. speed sensor-maf-map-o2-tps-evap-knock-crankshaft-egr-
-I checked all brakes-all u joints and rear-front shafts and rear differantial limited slip locks-bearings-teeths.
-I finally had the complate engine rebuild. Replaced piston 0,50mm, ring, valve seals,all lifters, oil&water pump, gaskets,all belts and other possible parts. Top cover grinding and adjustments were made. But no difference:(
Have you encountered such a problem before? Or another advice? I don't think so, I don't have any problems on slopes or at different speeds but maybe clutch maybe transmission maybe intake and exhaust valves? Sometimes Pathy works fine and this problem does not appear in this range itself. And this misfire has never happened for outside the 1500-2100 rpm range. My car can run fine for hours/ non stop 200-300 miles and its works always max 91 Celcius
I have a ODB scanner and i check all sensors referance values from the nissan service manual.I changed it even though i knew some parts were working. I have 2 trouble code but its not important. (back o2 sensors because cats empty and i tried sometimes unplugged mode) I checked long and short fuel trims but no problem on the values LTFT1&2 or STFT1&2 in the +%5-%5 range.
It is very difficult and expensive to find another engine in my area. I need your suggestions to solve the problem.
