dickie »
https://forums.nicoclub.com/dickie-u32299.html
Mon Jan 07, 2008 12:19 pm
you understand what a cam does, right?
with any drastic change in the way the engine is mechanically timed, you should be tuning your fuel to compensate.
its not a matter of "changing the computer: as much as it is finding good overall solution for your performance goals.
so you have a cam and you want to make better n/a power or build for a turbo? consider all of the supporting work that needs to be done to extract everything you want from the engine and then take it to be tuned by a professional unless you think you are up to the task.
just dropping a cam in is probably fine (you wont be getting ALL of the possible gains, though) unless its some extreme grind. if you want to really upgrade, consider more than just bolt-on accessories.
