ok so i made a list of wires i cut to separate the body harness from engine harness
What i am calling the "body harness" is the harness that splits off at the fire wall right after it comes to engine bay, it immediately has plugs that hook up the the ABS system then the rest of the loom travels along the left inner fender then across the core/radiator support to fuse box. Im assuming that i need that part of harness to stay with the car.
the "engine harness" is what travels along fire wall to the motor.
i also self named some of the plugs or mini looms/harnesses that branch off 1-4. i will psot a pic of each mini harn or plug with a label to help make sense of this.
you will also notice some have mutiple choices, thats because i went by wire colors i didnt chase them back to the ECU yet to see exact pin. thats next so i can limit those down
Wire colors------------------Pin out ----- From -----To---- Function
Orange DblSilvrStrps-------4 ----Harness 3 --- ECU --- ECM & IGN coil relay control signal
Black/White----------------72 ----Harness 3 --- ECU --- control unit power
White/black----------------80 ----harness 3 --- ECU--- battery power supply
-------------------------------5 ---- harness 3--- ECU --- Tachometer drive signal
-------------------------------114 ---- harness 3 --- ECU--- Injector no. 4 cylinder drive signal
Black/White-----------------72 ---- Harness 3 --- ECU--- control unit power
White/green-----------------109 ---- Harness 3 --- ECU --- control unit pwr supply (counter
--------------------- electromotive feed back circuit)
thick grey wire made of 3 smaller wires… intel unknown at this point
Red/Black--------------------79 -- plug 1 ---- ECU --- ECM/TCM/TCS/ABS intergraded cntrl sgnl
White/black------------------80 -- plug 1 ---- ECU--- battery power supply
-------------------------------- 5 -- plug 1 ----ECU--- Tachometer drive signal
--------------------------------114 - plug 1 ----ECU --- Injector no. 4 cylinder drive signal
Green/orange----------------31 -- body harn. ----ECU --- ignition powr supply
---------------------------------78 -- body harn. ----ECU --- aux. electric fan relay control signal
Blue/yellow-------------------104 - body harn - ECU --- variable intake control solenoid vavle
White/black------------------80-- body harn -ECU --- battery power supply
--------------------------------5 -- body harn -ECU --- Tachometer drive signal
--------------------------------114 -body harn - ECU--- Injector no. 4 cylinder drive signal
Blue/black-------------------48 -- body harn- ECU --- pwr sup for TPS, refriferan pressure
----------------------------------------- Sensor, and turbo pressure sensor
Black--------------------------32 -- body harn- ECU--- control unit ground
Green/yellow DblSlvrStrps -66 -- body harn - ECU--- DB (databush 3 signal) rb25det a/t
Green/red DblSlvrStrps ---14 -- body harn- ECU --- AC control signal
Grey/red---------------------20 -- plug 2 ---- ECU --- Ignition switch (START) signal
--------------------------------120- plug 2 ---- ECU --- lockup solenoid valve control signal
Black SlvrStrps---------------25 -- plug 2 ---- ECU--- Control unit ground
Grey/blue DblSlvrStrps------17 -- plug 2 ---- ECU--- malfunction indicator lamp
Yellow/black DblSlvrStrps---22 -- plug 2 ---- ECU--- (CHK) check (Diagnosis start)
Orange------------------------111 - plug 2 ---- ECU--- Fuel pump terminal voltage
------------------------------------------ Control signal (rb25det)
Pink DblSlvrStrps------------21 -- plug 2---- ECU--- AC switch signal
Black/pink DblSlvrStrps----13-- plug2 ---- ECU --- fuel pump relay control signal
Brown/yellow----------------75 -- plug 2 ---- ECU --- (RX) receive (data input to control unit)
Red/blue---------------------9 --- plug 2 ---- ECU--- ign signal (power transistor) cyl #4
--------------------------------23 -- plug 2 ---- ECU--- throttle position sensor signal
Yellow/red DblSlvrStrps-----29 -- plug 2 ---- ECU--- vehicle speed sensor signal (sensor 2)
Pink/blue---------------------71-- plug 2 ---- ECU --- stop lamp switch signal
Green/orange----------------78-- plug 2 ---- ECU --- Aux electric fan relay contrl signal rb25
Black/white DblSlvrStrps----49 -- plug 2 ---- ECU --- rear defogger switch signal
White/black------------------80 -- plug 2 ---- ECU --- battery power supply
------------------------------- 5 --- plug 2 ---- ECU--- Tachometer drive signal
--------------------------------114 - plug 2 ---- ECU --- Injector no. 4 cylinder drive signal
Other wires cut from R34 GTT harnesses
Wire color---------------------------from ---------to
Black/green SlvrStrps---------------Body harn----Plug 3
Black/white--------------------------body harn----plug 3
White/black-------------------------body harn----plug 3
White/blue--------------------------plug 2-------engine harn
Brown--------------------------------plug 2-------engine harn
Red/white---------------------------plug 2-------harn 4
Brown/yellow DblSlvrStrps---------plug 2-------harn 4
Grey/red----------------------------plug 2-------harn 4
Green DblSlvrStrps-----------------plug 2-------harn 4
Green DblSlvrStrps-----------------plug 2-------harn 3
Yellow/red SlvrStrps---------------plug 2-------harn 3
here is the plugs and mini harnesses i marked as 1 2 3 or 4 in my break down on previous post attachments
