Not true.Bigalow311 wrote:Wikipedia has some good info on the rb26dett. Apparently the N1has better technology and the Nur is just a beast version of the block besides the GT500
Don't forget the diff. I will tell you from personal experience, the cars react fairly strange with 4.111 in the front and 3.545 in the rear. Kind of feels like a super hard rev cut under throttle when ATTESA splits some power out.Gold Digger wrote: And also swap the front diff of the R32 onto the newer motor.
It's that simple...
Gold Digger wrote:Ouch!!!
Sean...how much to hire you as my full time mechanic/tuner? Do daily bento lunches cover your experience? Japanese hookers? Or do you go much higher than that? LOL
How is that 'not true?' The N1 has better water channels than the regular 24U, right? That's the 'better technology' I was talking about.tyndago wrote:Not true.Bigalow311 wrote:Wikipedia has some good info on the rb26dett. Apparently the N1has better technology and the Nur is just a beast version of the block besides the GT500
The latest/greatest was the RRR block. The later N1 blocks, from what I can tell and hear, have more problems than some of the older "seasoned" blocks.
The Nurs had an N1 block in them.
N1 block is a 24U block. Seriously you are better off with a good old block, we call them "seasoned". I've built, and broken them all, and I have no problem using whatever you put in front of me. Unless you are going for 1600 hp, don't worry about it.Bigalow311 wrote:
I want to build my RB26 but it's a 20+ y/o block and I'm concerned about it's reliability. What can I do to make the block last for another 10+ years?
I have lived in the US since I was 5 years old, so, sorry no NZ accent.Bigalow311 wrote:Wait, no NZ accent? WTF? lol.
Thanks for the info on the oil pump. A lot of other Skyline owners have said that Tomei is the best but the Nismo 1 is the best bang for the buck. I guess I don't need to drop a newer R33/R34 block in there so I'm planning doing a build with CP rods and pistons. I'll probably upgrade the crank to the Tomei 1 that has the extra cooling channel. As well, I'll use the Tomei baffle and perhaps the Nismo oil pump. My biggest priority is reliability and safety.
Any other 'concerns' I should have getting a 89 RB26?
