R34 Brembo Calipers on a 95 240 . . . Rotor help . . .
JDM S14 Silvia
not the Z32s. The shop tried that already, so I was told. I bought the Brembo R34 calipers on the boards, w/o rotors. I was under the impression that these were the same as the G35/Z33 calipers sold here. Will the OEM G35/Z33 rotors work? any one else had this issue? Thanks in advance for your help . . .
cdlong
Car: '95 240sx
from Disk brakes australia's catalogue. http://www.dba.com.au/dba_cata...b.pdf diameter offset thicknessR34 GTR 324 53.75 30 Z33 brembo 324 49 30
looks like the offset is off. (actually it's over all thickness)
if you were desperate you could put a 5mm spacer between the rotor and hub.
