r33gtst conversion
stewpot
Car: r33 gtst
i am building an r33gtst and fitting the awd system in it ,i have modified the chassis rails and gear box tunnel fitted all gtr suspension in and now i am working on the awd system, my gtst is a spec one with no abs so i am fitting this in to, can any one help regarding wiring the awd i have the ecu and wiring loom ,and i have looked at connecting to the gtst loom but nothing looks like it will fit easily , any ideas from any one will be welcome, i have a feeling i can just wire it up to everything on the wiring diagram and it will work,or would it be easier to get a gtr loom ,
RicerX
Car: '20 Titan Pro4X
welcome to NICO!
sounds like a pretty major project. my bet would be just getting the harness from a GT-R since that is basically what you will get to once you get to a working state with whichever avenue you pursue. I'm sure someone more experienced will jump in and correct me if I am wrong though.
stewpot
Car: r33 gtst
hi thanks i have got that in mind ,your right its major but good fun,and will it go ,
