r33 xmember question
OKRB20DET
Car: 1990 S13 coupe
people say the rb20 will not work on the rb25 xmember..the 25 xmember has 2 holes where the mounts gothe 20 xmember has 1 hole/slot where mounts go..
if i were to cut out the section on the r33 xmember between the 2 holes making it 1 slot, would i be able to use it then?
OKRB20DET
Car: 1990 S13 coupe
Carl H
proly not.iirc the rb25 mounts a bit diffrently than the rb20 does hence the diffrence in xmember.if you get some rb25 mounts it *should* work but fitment is crap with the r33 xmember so the r32 is the best bet.
