pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Tue Aug 01, 2006 7:53 pm
it should work but i dont know about the j30 axles. you definately need either the output shafts from a vlsd with the correct axle pattern or you can use jdm vlsd axles as they have the 5 star pattern. either way 20 bucks is a steal for the diff so any money you spend on the correct axles you will still have gotten a bargain. also you do need the rear cover from your stick diff but that is nothing to swap
