r33 vlsd input
oneslow240se
Car: 91 240se
i been trying to get some info as far as gearing on the vlsd diff off the r33.. i did the search and saw two post and the rest were either the J30, R32, jdm 180sx/240sx...
was wondering if anyone has info or can point me to a post/forum with this info, so far all i gathered was i need the 5 bolt axles and change out the rear cover for stock s13 4 bolt cover and that its 1inch longer? .. basically i'm in search for vlsd since my sr swap is complete.
Will be daily driven and occasional drag... so any comments on the r33 vlsd or am i better off going with the others mentioned........
thanks
karmakaze
Car: 98 240sx SE
oneslow240se
Car: 91 240se
thanks man
oneslow240se
Car: 91 240se
still not many people have this swap so the search came up limited.... will this swap be the same as the J30 as far as fittament using either j30 5bolt axles or the ones that comes with the r33 and swaping the rear cover? .. i'm trying to pick this unit up but will like alittle more info on the swap...
thanks
karmakaze
Car: 98 240sx SE
oneslow240se wrote:still not many people have this swap so the search came up limited.... will this swap be the same as the J30 as far as fittament using either j30 5bolt axles or the ones that comes with the r33 and swaping the rear cover? .. i'm trying to pick this unit up but will like alittle more info on the swap...
thanks
you will need the j30 axles. i am pretty sure thats an r200 rear end. if it is, you my need to swap the cover but asides from that it should fit the same.
oneslow240se
Car: 91 240se
so the r33 axles are different and cannot be used? don't mean to ask too many questions, but just trying to get some facts.....
