Well, I am guessing that since you said just GTS, that it's an RB25DE, correct?Or is it an GTS25?
Either way, check out the RB forum and post up there, you might have better luck as that's a dedicated RB engine forum here---->
zeroforum/135
And I would suggest maybe try replacing the MAFS, or checking your IAC (Idle Air Control) valve to make sure it's clean and working properly.
