R33 Speedo Convert
mrflip69
If I use a Z32 N/A VSS with the R33 cluster, would that convert the output to mph?
Would I just need the speed sensor, or is the pinion needed as well?
mean240
Car: 240sx,crx
mrflip69 wrote:If I use a Z32 N/A VSS with the R33 cluster, would that convert the output to mph?
There is a way to convert the r33 cluster to MPH . you have to open up the cluster and weld a few things.. I tried finding the link for you but i can't find it... its in another forum.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
i got this off skylinesdownunderits suppose to be 1mph off but i havent got the chance to test it out yet-after you pull the speedo out of the cluster you will see this circuit board on the back of the speedo
before
after
mrflip69
That using the RB25 speed sensor?
Appreciate the help guys.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
mrflip69 wrote:That using the RB25 speed sensor?
yea thats using the rb25 speed sensor
GIJOE69
Car: Going Side Ways!
so circuit J2 is jumped by solder?
mrflip69
And closing 8/9
I wonder if this fixes the Odometer too?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Don't forget #6 too.
300Plus
Car: 1995 S14 w/ Rb25det Series II
mrflip69 wrote:And closing 8/9
Does this fix the odometer? I'll probably yank out my speedo and do this, this weekend
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
yea jumping j-2 is supposed to change the odometer to mph
Darius
That sounds right. The numbers are solely for the speedo calibration.
300Plus
did this today and now speedo doesn't work at all. after finding the original thread there is a lot more to the convo, 10 pages actually.
The original poster of the pictures above also cut the "PESL" connection, its hard to see in the picture but he actually cut the PCB (printed circuit board) so I'm going to open my speedo back up and instead of cutting the PCB I'm going to try and just de-solder the jumper. Hopefully this will fix my speedo
but some people have had to desolder 4 and 5 and a lot of other combinations.
