r33 series 1 or series 2
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
ecr33noob
Car: Infiniti Fuga
how do i know which one i have...they said that all series 2 have dual airbags but mine doesnt...i know i have a series 2...i thinkplease help...thanks
by the way...which do you guys prefer: HKS fpr or NISMO fpr??
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
Are you referring to the car itself or the RB engine?
If you are asking about the engine, let me know and I will move this over to the RB section as you might get better response over there.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
as far as the car its self this is a series 2
and the inside
now for a series 1 inside
and the bumper is also diffrent
look at the red car
ecr33noob
Car: Infiniti Fuga
my car looks like the red car but only in white; however, my motor doesn't have the resistor box for my ignitors like series 1...i am confused...thanks
sean8564
1993 Nissan Silvia
you have an series 2 motor in the series 1 car. 1 of 2 things happened 1st the motor was blowen up in Japan and you got a new motor. 2 the shop putting your car back together put the wrong motor in the car good for you mabey? I have a freind of mine whom bought a R33 and did not know and his car turned out to be and abortion car he has a 1995 R33 Series 2 motor series 1 maf and wring harness the motor is constanly fowling plugs and running rich I do not know why? Fuel pump went out after 2 days of having the car.
ecr33noob
Car: Infiniti Fuga
what could i do to solve that problem of foul plugs...thanks
sean8564
1993 Nissan Silvia
1 check the spark plug gap 2 check your MAF and make sure you are in time 100% 3 Check and make sure your coil packs are good and firing right and are clean from corriosion.
Dose your car brake up at the high RPM's?
ecr33noob
Car: Infiniti Fuga
sean8564 wrote:1 check the spark plug gap 2 check your MAF and make sure you are in time 100% 3 Check and make sure your coil packs are good and firing right and are clean from corriosion.
my car sputters when i full thottle...
sean8564
1993 Nissan Silvia
yeah i am starting to belive that all RB25 do that or at least every one that i have owned. check those three things if it still goes on hit me up and i will see if i can help you more. Do you have cld start problems as well?
ecr33noob
Car: Infiniti Fuga
sean8564 wrote:yeah i am starting to belive that all RB25 do that or at least every one that i have owned. check those three things if it still goes on hit me up and i will see if i can help you more. Do you have cld start problems as well?
Yes Sir...it starts and then dies in cold weather...thanks
sean8564
1993 Nissan Silvia
then also check the temp sensor that goes to the ECU ther is 2 of them. The smaller one goes to the gauge cluster and the bigger one goes to the ECU un plug the one to the ECU on a cold start and see if it starts right up if it dose then that is your problem.
Return to “GTR Forum / Skyline Forum”
