Dattebayo wrote:No.
umm there not direct bolt in, so dattebayo was rightskott.b wrote:
UHm I beg to differ sir.
3 bolt will line up perfectly. as for the 4th bolt. which will be the back one close to the door. Its a bit short. so you have two choices. use the bolt from the s13 seat and let it over lap the bracket and it will hold.
(Or)
you can drill a hole in the floor. then sandwich it. (bolt, washer, floor board, seat bracket, washer, nut and call it a day. I myself chose to over lap it and it works fine.
~skott
..... For them to be bolt up it would require ZERO modification. Having to shim the bracket or bolt the side of the seat is not only the half *** rice way, But isn't bolt up.skott.b wrote:well damn if thats the case. then you might want to swing buy my house look at my seats and prove me wrong.
He said "direct bolt in". All that stuff you said is far from "direct bolt in". SO I answered his question. right back atchaskott.b wrote:
how wondering close was the bracket in the S14? where you able to over lap it?aymaeid wrote:not a "direct" bult on but well worth the extra effort
No idea, im sure someone will pop off saying so. But i have been eyeing some on ebay. been thinking about getting those as well. then making PC chairs out of the R33 seats. For the record R33 seats into a rolling office chair base is not a direct bolt in. fabbing and welding is needed.ThuG LyFe wrote:sweet they look pretty close to r32 seats.
is it the same deal with r32 seats? 3/4 bolt in?
i would imagine it's about the same since the s13 and s14 seats are interchangeable, the brackets are probably almost, if not exactly, the same.skott.b wrote:how wondering close was the bracket in the S14? where you able to over lap it?
Oh yea? You should have seen me trying to get S14 seats into an S12. Now THAT was a welding project that needed some skillz y0.skott.b wrote:For the record R33 seats into a rolling office chair base is not a direct bolt in. fabbing and welding is needed.
lawlz what you cant jus use a ford wrench and some j b weld to get em in. BYW your on lkt right, yo?Dattebayo wrote:
Hellz homie in janky productions if it doesn't involve cutting, welding or massive beatings its a direct bolt it. rotflol. we can deal w/ some janky ****e. thats why we make race cars from junk.jessetang wrote:
Skott.b, I did the same thing you did on my old S13, so I know it works. However, it is still not a bolt on as the screw is not 100% secured in the position. I highly doubt that the bracket would come loose (and I can live with that).
You still modify the way the seat is held in the place.
looks good cant see your feet. lol.iitywygms wrote:If you look close at the feet brackets, they are held onto the seat rail with 2 spot welds. If you drill out the spot welds, the foot bracket will come off. What I did is drill the back left bracket off of both seats and swap them using a couple of bolts. After that, the r32 seats bolted right in like they were meant to be there.
try properly mounted 350z seats in an s13, not hard just time consumingDattebayo wrote:
I'm not familiar with w/e LKT is, so help me out on that one, plz?skott.b wrote:lawlz what you cant jus use a ford wrench and some j b weld to get em in. BYW your on lkt right, yo?
The rails in an S12 are almost the same distance apart as S13 and S14 rails are, but a little wider. the front two are the only ones that sort of bolt in if you use longer bolts and drill them out a little. Everything else had to be measured and spot welded on, and then checked for consistency with previous placement.
It took me 4 grueling hours of trial and carpet removal.
lol it has lock tight it holds, even while sliding. so i consider its safe. as well so has others that have looked at it. ppl that inspect cars for events. so if they deem it safe, then it shall be safe. thank you.dsc4130 wrote:
are you guys serious? doing it the right way is not only easier, its safer!!!!
you can say oh its fine but when you come haulin a$$ into a turn that bolt lets loose and it sends you back your going to crash.
