dont see why they wouldnt, r33 rotors are 114.3x5 32 mm and the z32 are 114.3x5 30 mm if TT and 26 mm if N/A same diameter, it would be just like having resurfaced rotors slightly skinnier. Besides the box of green stuff pads says on it, skyline, z32, WRX..... so yupChaos the Xile wrote:i heard they would but I need a deff, answer "should" is not in my vocab when it comes to safety stuff like brakes.
all nissan 5 lug is 114.3x5, that is irrelevant. r33 gt-r is brembo so that is also irrelevant. r33 gts-t is 10mm bigger in diameter than z32, same thickness (30mm). r32 gt-r is also 10mm bigger than z32 and 32mm. i wouldnt be surprised if the PADS are all the same, but if you use a 10mm smaller diameter rotor it will eat into the pad and give you less surface contact. the answer to the original question is no, you're not supposed to but you can. try shopping for the bigger rotor. not sure if the gt-r rotor will work since its 2mm thicker than r33 gts-t.Shocker wrote:
AFAIK all of the sumitomo 2 pot rears are the same caliper/rotor.
Sure about that? The diameters are both 296, but I always thought the rotor thicknesses were different. I've never measured an R32 GTR caliper so I dont know, but I've always read they're 32mm.Carl H wrote:r33 gts-t's use r32 gtr front brakes, simple as that.
