underground »
https://forums.nicoclub.com/underground-u11170.html
Sat May 22, 2004 3:16 pm
The swap would be a breeze, it's basically a bolt-on.
This turbocharger incorporates the ceramic blades for the very quick spoolup and makes the car fun to drive.
The light turbine blades mean quick spool up and good top end power! Garrett T28 with intake side of A/R .42 and exhaust side of A/R .48. The intake blades are aluminum and the exhaust blade is ceramic for quick spoolup. Super light!
Thrust bearing metal is 273deg metal, and the center cartridge is T25.The compressor size is T3/50trim and exhaust size is T25/62trim.These turbos are capable of making appx. 460hp at 19psi. You should not go any further than that with these turbos, as it will break the exhaust blades.
