If anyone has any pointers I would appreciate it.
I have an R33 RB25DET S2 in a 97 S14 (originally automatic car)
Mods:Greddy Intake / Q45 TBGT3076HKS FMIC / GREDDY Type S BOVCustom ExhProfec B spec II BCAEM WidebandNismo FPR
The car starts, and drives ok on the stock ECU. I modified my S14 Chassis harness instead of the RB engine harness figuring that if I screwed up - easier to get a replacement S14 dash harness. [stock RB ECU P/N# 23710 13U00]
Car idles fine, but runs poor. AFM would bounce from lean to rich so I figured it was due to all of the modded parts and I should get an engine management system. I bought an Apexi power FC.
When I plug in the power FC (brand new unit - model # PFC ERC33 010-2667) - the car will crank, but not start. I do not hear the fuel pump run either. When I plug in the commander, it does not light up.
If anyone knows of a circuit other than the standard ones which needs to be connected - I would appreciate a heads up. Everything not listed is CUT. All circuits are good, soldered, and heat shrunk. Again - this is a little backwards to all of the how to lists as I reversed the harn mods to the chassis side of the M63 Connector.
PIN Color Fuction To MOVE TO1 B/R KEY ON ign switch 124 P WASH SW Wiper amplifier 75 LG/W 156 LG/B WIPER SW HI Wiper motor 137 LG/R WIPER SW Low Wiper motor 58 BR OFF / INT WIPER Wiper amplifier 1010 B/Y COLD IDLE IACV 2111 B/P FUEL PUMP RELAY 2015 PU/W PWR STRNG press switch 1117 R BATT + ECCS Relay 2420 R KLINE CONSULT 3822 G SCITX CONSULT 1823 G/W SCICL CONSULT 2224 Y/G SPEEDO Combi meter 3926 L/B TACH Combi meter 3527 L/Y INT SW Wiper amplifier 128 Y WATER TEMP Combi meter 1930 OR WARN LAMP Combi meter 3634 OR KEY START ECM 3738 G/B SCIRX CONSULT 2342 PU INT / VR WIPER Wiper amplifier 9
I am going to start digging through the RB ECU pin outs to try to diagnose, but any help is appreciated.
Thanks
Thomas
