R33 GTST Front and Rear Rotor Parts Source?
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
Hello NICO,
I have SFTA and it's been difficult to obtain a reliable, straightforward answer for a question about part swap-fitment information. I am helping my friend find an install replacement front & rear rotors on his 1995 Skyline GTS25T.
I work for an auto parts aftermarket wholesaler who happens to carry a vast selection of USDM replacement parts. Unfortunately, none of the Skylines or other JDM only vehicles are available for lookup in any of our paper or electronic catalogs. If I was to replace both Front and Rear, Brake Pads and Rotors for his 95' GTST, which USDM vehicle could I reference parts from with 100% accuracy.
If you are absolutely sure that there isn't any USDM vehicle to reference parts from, the please point me in the right direction with a) OE Part Numbers b) aftermarket brand part numbers c) if all else fails, the exact measurements of the rotors and pads.
Your help is very greatly appreciated! It's been a while since I've been on here but was the first choice in my head for help in this field of information.
Thanks in advance!
-CK
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
Check them to a Z32 Fairlady Z for size.
Those might work.
As for pads, possibly off of the same vehicle. I would take a rotor and a set of pads to a dealer/brake shop and compare what they would have in stock to see if you could cross reference them.
If those won't work, let me know and I'll see if I can find the part numbers from an R33 GTS25-t and let you know what they are.
InjectedPerformance
Car: 2009 Nissan GTR, 2004 Nissan 350Z, 2009 Nissan 370Z
Go to http://www.DBA.com.au
Plug your car in the search. It will list the overall dimensions of the rotor. I would measure your rotors just to make sure they're on par with DBA.
As for the pads i'm not too sure. I guess you can send me the pad shape and i could find it that way.
got2b240
Thank you for the info guys. Part numbers might help. I think we have the pads right, but it seems that the rotors are slightly different. The rear rotors on a Z32 don't have the inner size/space for the emergency brake setup (drum type) that the GTST needs....but the rear pads are identical!
After finding out the rear rotor didn't fit, we gave up trying out the fronts because it was outside and too cold up here in NY now... brrr
I have a feeling that the front pads and rotors from the Z32 might not fit anyway...
We appreciate your help
Marty T wrote:Go to http://www.DBA.com.au
Gold Digger wrote:Check them to a Z32 Fairlady Z for size.
Those might work.
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
The pads from a 300zx should work all around. We have the fronts from a GTST on our Time Attack 240sx, The rotors are very similar to a Non-Brembo Z33 350Z. I have a set of OEM Z33 rotors that I need to still try out, I know that the outside diameter and thickness are similar, not sure about the offset from the hat though. Goodluck!
got2b240
MagikDragon, Thanks for the useful info please let us know if you find those Z33 rotors to work!
MagikDragon wrote:The pads from a 300zx should work all around. We have the fronts from a GTST on our Time Attack 240sx, The rotors are very similar to a Non-Brembo Z33 350Z. I have a set of OEM Z33 rotors that I need to still try out, I know that the outside diameter and thickness are similar, not sure about the offset from the hat though. Goodluck!
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
z32 300zx front n rear rotors r the same along with the pads, the only diff is some of the calipers were aluminum and some iron, the aluminum calipers had a 26mm thick rotor and the iron had a 30mm wide rotor, these sizes r fro the front, rears should be the same
MagikDragon
^wrong R33 is a different beast, We had Z32 calipers and R33 next to each other, where the pads are the same the rotors/calipers are very different. He has already tried Z32 rotors with no luck. NO he is searching for solutions.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Like Magik said they are different. Those rotors are unique to the GTST. DBA is the only company that I have found that can get the rotors. Forget trying to find 2 peice rotors unless your making them yourself. They are great brakes, now if only you could get the parts easier.
got2b240
SullivanRacing06 > Thank you for your efforts.
MagikDragon wrote:^wrong R33 is a different beast, We had Z32 calipers and R33 next to each other, where the pads are the same the rotors/calipers are very different. He has already tried Z32 rotors with no luck. NO he is searching for solutions.
You are right MagikDragon--So far I will confirm that the REAR ROTORS are not the same as the Z32 300ZX, as the R33 GTST's emergency brake/parking brake assembly needs a larger diameter and breadth of the inner-rotor.
the converted wrote:Like Magik said they are different. Those rotors are unique to the GTST. DBA is the only company that I have found that can get the rotors. Forget trying to find 2 peice rotors unless your making them yourself. They are great brakes, now if only you could get the parts easier
Thank you for confirming the truth. It's imperative we keep all user contributed data clean
I will agree that DBA has the specs and the parts available for purchase directly from their website. If and when we can find an *EXACT* match for the 1995 R33 GTS25T to the application fitment of a USDM vehicle, we will be sure to dig up this thread and contribute in perfect detail on how to proceed.
GoldDigger > typical of a "gold digger" > you come...sniff out...then bounce!
Thank you all for your help!
SullivanRacing06
wtf is "im searchign for solutions" mean? sorry i was trying to put my .02 in, $hit, sorry if i gave wrong info here, ive installe dz32 brakes on a r32 befroe, sorry for assuming there the same, thought the calipers were the same
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Nope, z32 rotors are 280mm, r33 gtst rotors are 296mm. If you use the smaller rotor you can use the smaller caliper but you wouldn't want to.
EL MAMITO USMC
Car: SENTRA SER
Marty T wrote:Go to http://www.DBA.com.au.
get the parts from this guys and the pads are the same as a z32. i know because that the ones that we use in my friends car.
got2b240
Perfect. I think we will choose to do just that, as our need for changing the complete friction setup is needed soon.
Cheers!
-CK
EL MAMITO USMC wrote: get the parts from this guys and the pads are the same as a z32. i know because that the ones that we use in my friends car.
Return to “GTR Forum / Skyline Forum”
