r33 gtst 5 lug hubs on my s13?
Cynxe
Car: 240sx, awd talon
I have some 5 lug hubs, brake rotors and big skyline calipers, will they work on my s13? I also have all the axles and the rear differential. I'd like to avoid trying to find some z32 hubs as i cant ever find a whole set. Will what i have work? :confused: :confused:
Hijacker
Car: '92 240sx Convertible
'94 F-150
Fronts won't work. You'll need to get conversion hubs or do a full S14 upright swap.
For the rears, they'll fit, but check the spline count to make sure they aren't the larger sized variant found on the GT-R and Z32 TT. I had a set of rear hubs I was told were from a GTS-T, but the S13 axles were way too small for them. I'm pretty sure they were from a GT-R. The entire rear had the larger the diff and axles as well. A buddy of mine was going to try and hybridize the axles so he could run the diff on his S13, but I don't think that project ever got any traction (no pun intended).
You can find Z32 rear hubs online fairly often. I found a set a few years back from an N/A 2+2 that are a perfect fit.
As for the brakes, the brakes should be similar to the Z32 setup, so they should fit with no issue. My rear e-brake is from the same skyline the hubs and uprights came from. The e-brake is currently installed on my S13 iron uprights, and I have Z32 rear calipers mated to it with brembo Z32 rotors re-drilled for 4 lug.
josh89s13
Car: 1989 240sx s13 sr20det
hey im having trouble finding out if my stock s13 differential axle shafts will fit in my r33 gts diff? if you have any information it would be helpfull
