R33 GTS-t VLSD
JCAP_Tuning
To those who have installed the GTS-t VLSD in their cars or if you know, what all did you need to install the Skyline diff? output flanges and pumpkin or what? Thanks.
DCIracer
You will need to use the output flanges of the skyline (half shafts) as well and the pumpkin assembly. Some GT-R lsd's and GTS lsd's have the 2 bolt pattern that will not bolt directly into your 240 (hicas caused this), so you can replace the diff backing with your stock 240 diff backing and viola have it installed in no time. It uses the same flange for the driveshaft so there's not too much custom work.
Imissmyturbo
Car: Car's, Turbo's, sking
The LSD I installed was from a rear end with HICAS and I didn't have to do any mods to get it to fit. Bolted right up.
DCIracer
Did it have a two bolt or four bolt rear casing? Most LSD's from a Skyline with Hicas have the two bolt pattern instead of the four.
Imissmyturbo
This one had 4 bolts. I am 99% sure it's from a Skyline because I have the whole rear end that has twin piston calipers and 11" vented rotors. It also has a steering rack on the back too. It's either an R32 GTS or R32 GTR.
cyris3d
i had to change the rear cover of the LSD i got.. i just swapped it out with my 240 rear cover.. just buy a new gasket from the dealer.. and i also used the Skyline axles.. i belive the 300zx TT axles are the same.. 5 bolt.. and length
DCIracer
Yes Cyris, you are correct. The 5 bolt 300ZX axles are the same as the Skyline axles.
JCAP_Tuning
So basically, you guys were able to use the 240 driveshaft, just used the output shafts and pumpkin, and used 240 axles?
We have complete rear ends for z32 TT and r32, r33 and soon will have more coming, I just thought for some reason more was involved. I guess I will try and use the rear end that came with my motor.
Thanks.
cyris3d
no.. use the skyline axles also.. or u can use 300zx axles.. they are deffintly stronger.. they have the5 bolt flange u need for the skyline lsd.. the 240 axles are either 6 or 4 bolt.. cant rememberand i had a custom ONE piece driveshaft made..
msg
by anychance would ne one have some output shafts for an r200 lsd?
JCAP_Tuning
if you just need the shafts, we have a dozen, just give me a call 919.759.0533, I am assuming you have a LSD pumpkin, with the flanges on the ends though, dont have those.
S13Sil-line
Car: Full throttle-*** out sideways
I have an LSD from a JDM 180. Im putting it into my 90' fastback. I dont have the flanges.... What should I do???????
JCAP_Tuning
you can probably pick some up from the junkyard from a 95-96 Infiniti j30 or 240sx that had VLSD.
