oreofreak »
https://forums.nicoclub.com/oreofreak-u10457.html
Fri Oct 17, 2003 12:10 pm
You did not get an R33 lsd diff. You are right the R33 lsd have 5 bolt axle flange. It sounds like you got a diff from a big VIP car aka(Y32,Y33,Nissan Cedric or Gloria) It may not work. Try getting axles from a Infinti Q45 I think there' the same. Also check to see what gear ratio you have by opening the diff up and counting the pinion gear teeth and ring gear teeth. R33 gts-t have 4:1 gear ratio. Y32,Y33 may have a higher gear ratio not good for quick take off which may suck!!
