R33 GTS-T Front Brake to S14 Question...
SStrunks
Car: 1994 Honda Accord & Soon to be a RB25DET S14
After reading all the threads available on this topic im still alittle confused as to what is interchangeable. So my question is...
If I install R33 GTS-T front brakes on my S14, what rotors/pads can I use? can I use the z32 rotors/pads? I was thinking about buying some project mu rotors/pads, and I'm confused as to which ones to get...Also, what can I use for stainless steel brake lines for the front R33 GTS-T brakes? Thanks ahead of time for the help.
Searched these topics already...I would've just posted in these topics but they were archived. zerothread?id=228430http://forums.nicoc ... d?id=88782
Bluefire
well this is a rb engine forum, but i'll answer your question anyways...
Pads: Z32Rotors: Gtst, if you can't find any then you can use z32 rotors but they are 10 mm smaller so you will have a slight pad overhangLines: Z32 to 240sx conversion lines
SStrunks
thanks for the help, i figured this part of the forums get more traffic than the brakes/suspension forums and since many of you guys probably had front clips when you did your swap i figured most of you might swap brakes as well...but thanks for the response anyways.
Carl H
r33 gts-t front brakes are stock r32 gtr brakes, nissan sells discs and pads.
Shocker
Car: 89 240sxHB rb26/30
Carl H wrote:r33 gts-t front brakes are stock r32 gtr brakes, nissan sells discs and pads.
you have a local dealership that sells them?
Carl H
yare.they dont like to order them for me but they do...gotta love being an ex-employee.
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
http://www.courtesyparts.com/
They're expensive, but they do carry them.
