R33 GTR Gauge Cluster
Audi180
Car: RB26'd S14
Hi...I have the R33 GTR gauge cluster, and i wan't to fit it in to my S14..Is it possible?, what modification should't i do?
thanks,Tom
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Yes, it is very possible to fit that cluster into the s14. It actually fits extremely well and will look like it came from the factory that way. The wiring is more tedious than difficult so take your time and do it correctly.
Ramius83
Car: 1995 240sx SE
You will have to make sure that you have the plugs that go into the back of the cluster. You will have to mate those plugs with the wires in your car. Not very hard, just time consuming. Take your time, don't rush, and draw out exactly which wire will go to each wire on the plugs....
Joe
you will have to do some trimming of the bezel and top of the cluster to get a factory fit. i have a r33 cluster in my s14.
the wiring is very time consuming so just take a night and plan everything on paper.
Audi180
Car: RB26'd S14
where can i get the wiring diagram for that gauge cluster?i have the workshop manual for the R32, not for the 33...and i don't really know if i have the plugs in it...it's on it's way from japan..if i won't have them what can i do?
thanks alot for all of you guys!!!
Tom
Joe
if it dosent have the plugs you gonna haveto try and run some really small spade connectors and just plug directly into the cluster.
and as for the wiring diagram everything on the back of the cluster is actually labled. ill post up the stuff i traced out tonight when i get home.
goofynick6
Car: 1995 S14.5 RB20DET
That tachometer looks amazing...I just want a whole R33 RB26....*sigh
dekand
Car: 1995 240sx SE
I did the r33 cluster wiring for my car in about 3 hours so as long as you take your time and lay it out like others have said on paper, it is very simple.
just remember, twist and tape first, make sure everything works, then solder.
CKs240sxNC
Nice dude, how much did you pay for that and where did you get it?
Audi180
Car: RB26'd S14
it cost me 150$, i've bought it from the auctions in japan...i also bought my RB26 from there for 1500$
GTR14
Car: 2003 audi a4 1.8t
1998 Kouki s14
Audi180 did you ever get that wiring harness layout i am about to be attempting the same cluster swap and could really use the assisstance.
meet07
Car: 89 180sx rb25det
Will the same thing work in a s13? I know the cluster are not the same looking as the S14? GTR cluster in s13 body powered by rb25det??
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
here this should help if you have a s14 zenki, i do have the kouki wiring diagram but I need to pull it from my file cabinet and scan it. here is the link http://www.nicoclub.com/archives/r33-gu ... iring.html
