r33 Gauge Cluster speedo wires
catch221134
Car: Nissan
So I have everything working on my r33 series 2 gauge cluster into a soch 89 s13, but the speedo. Sooooo Help me out here. What two or three wires do I need to complete it, so I can actually tell how fast I am going.
help a brudha out, I am going to court tomorrow... I dont need any more.
catch221134
Car: Nissan
Wow not one reply, not even from a moderator huh?? Hoooray for Nicco.
catch221134
Car: Nissan
bump for someone having to know this. come on peeps
300Plus
Car: 1995 S14 w/ Rb25det Series II
not too knowledgeable about the s13, but .... if you were in a pinch you could always just run the two wires off the speed sensor strait to the speedo.... not the "correct" way of doing it but works.
it depends on how you did you lower harness and your m63 re-pinning
catch221134
Car: Nissan
I would do that, and tried, but I just need to know the wire color for the speedo. I know the ones from the s13 side. just not from the rb side. Thanks for the follow up.
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
I ran the two wires directly off my speed sensor to the back of my gauge cluster. Just clamped them on the screws right behind the speedo and it works like a charm. Sorry I can't tell you wire colors and crap, but I traced the back of the cluster til I figured it out. It's only two wires.
Oh, and thats for a S14.
300Plus
if you have the pig tails off the r33 gauges and are trying to figure out witch one is the speedo wires then 1. they should be the same color as the wires off your speed sensor 2. look at http://www.racebread.com 's file section and look at my cluster wiring guide the colors should be on there.
catch221134
Car: Nissan
I do have the r33 cluster wires, and that is a good idea to get under the car and look for the same color. on the speedsensor. I know some time they get shifty and switch colors. So thanks for the reply's and for the guy that just clamped them onto the screws.
so you just found the two screws on the back of the cluster that actually just hold the gauge in to the cluster and presto?
thanks again
catch221134
Car: Nissan
also i peepd in racebreed to no avail so if you have a direct link that would be great. Thanks
