OKCA18DET »
https://forums.nicoclub.com/okca18det-u19368.html
Wed Jul 13, 2005 11:09 pm
1.will the R33 crossmember bolt right up to an S13 ?2.will an RB20 bolt onto the R33 crossmember with the stock rb20 mounts?3.if 1 & 2 work, will the motor position be higher or lower then that of a S13 which uses the actual R32 rb20 crossmember?
