webberfan04 »
https://forums.nicoclub.com/webberfan04-u42446.html
Wed Feb 14, 2007 3:55 pm
Yes the boost solenoid i was talking about is the one on the left side that attatches to the wastegate
As for how difficult the cluster was to install it was pretty simple and straight foward. All the wires are labeled on the back of the clusters its just a matter of cutting off your stock plugs and splicing on the skyline plugs. The cluster did need some trimming to fit, i think i just cut off about an inch around the whole thing and it fits snug and dosnt move at all even though none of the mounting holes line up. If you take your time and use your head its pretty easy to install
hxc_nismo, do you have the solenoid for the wastegate or the sensor for the gauge? i already have the solenoid but if you meant the sensor, how much would you want for it?
