R33 Cluster
TachPHD
does anyone have a diagram of the r33 cluster, what each symbol means and what some wires are? i have everything worked out except for the oil gauge, boost gauge, and speedometer. i want to do emissions... could anyone tell me the wires go to speedometer? i'm jsut directly connect the speed sensor to it.another thing, my cluster lights dont light up when i turn the switch to lights ons. only the light bulb lighting the fuel and temp is on. any help or suggestion would be nice.thanks
Modified by TachPHD at 12:49 PM 8/10/2006
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
TachPHD
ig o
240sx2nr95 wrote:zerothread/167770
-Dan
i got that. it helped alot, but i'm doing a s13, so things are slightly dif. i still dont know what some symbols mean. and what wires and symbol are the speedometer. i just want that for emissions.
300Plus
Car: 1995 S14 w/ Rb25det Series II
^^^ I realized recently i forgot about the speedo wiring. I'm guessing that the wires to the speedo (on the back of the r33 cluster) are those Japanese symbols. But this weekend I'm going to find out which ones they are and hope to take some pics and I'll update or add the speedo info to the guide. but as for me and a few others the guide seems to work great.
P.S... wish I could help more with the other gauges but I didn't use the oil pressure or boost gauge on the cluster. but you would have to run a additional wire from the rb oil pressure sending unit straight to the cluster since the interior harness for the KA doesn't have a pressure gauge,so that could be why you oil pressure isn't working. And the boost gauge I'm guessing receives its signal from the boost control solenoid through the ecu but again guessing since i didn't use that gauge. oh and I couldn't figure out why the gauge back lights wouldn't come on for me but the headlights works then realized the dimmer switch is on the cluster bezel (on the s14) and i didn't have it plugged in, so could be it. Hope that helps at all man!
Dano
TachPHD wrote:ig oi got that. it helped alot, but i'm doing a s13, so things are slightly dif. i still dont know what some symbols mean. and what wires and symbol are the speedometer. i just want that for emissions.
Sorry, next time you make a topic it'd be helpful if u can give important information like if it's s13 for s14 your talking about, as well as any other little info u can give to help others help u.
-Dan
TachPHD
oh
300Plus wrote:^^^ I realized recently i forgot about the speedo wiring. I'm guessing that the wires to the speedo (on the back of the r33 cluster) are those Japanese symbols. But this weekend I'm going to find out which ones they are and hope to take some pics and I'll update or add the speedo info to the guide. but as for me and a few others the guide seems to work great.
oh cool, that would be awesome if you can find out which symbols are for the speedo and the wires. thats all i really need. the oil and boost gauge, i'll do later. thanks again for the reply
TachPHD
240sx2nr95 wrote:Sorry, next time you make a topic it'd be helpful if u can give important information like if it's s13 for s14 your talking about, as well as any other little info u can give to help others help u.
-Dan
ok, that would be good, thanks for the look out.
TachPHD
300plus, you still there man? wheres the update?
gtrperformance
Car: FULLY BUILT 1989 USDM KPS13 W/RB20DET
Didn't someone on here already do the swap? He posted PICs and everything. If I find it, I'll post the link. Try searching too. It looks real good. I have a NISMO gauge cluster that I will be putting in. 280kph! NICE!
