nwmrkt wrote:if you do the r33/z32 brake conversion you can't run normal s13 suspension?
there two ways to go when doing the back, if you source the whole rear rotor, caliper, backplate, hub and knuckle all put together than yes you will have to run 300zx struts. 300zx struts use a forked or horseshoe bottom while the 240sx (s14)uses a eye or doughnut bottom. I just got the backplate, rotors, calipers and hub and assemnbled it onto my knuckle. Only problem was it was a b1tch seperating the hub, I had to use a 8lb hammer.
props to the importnut definitive guide to the 300zx brake swap. Came in very handy.
