Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Fri Nov 05, 2004 3:22 pm
DO NOT USE STOCK LINES WITH 300ZX BRAKES.the caliper is designed to be used with a inverted flare brake line fitting and will leak or possibly come undone if you use anything else.it is dangerous to do that, do not use stock lines on 300zx/r32/r33 calipers.
