So I bought a full r32 hicas subfram complete with diff, axles, hubs, calipers, rotors everything.
I was wondering what is going to be the best way to swap all of this into my s13 hatch. I heard that the whole subframe should bolt right up but I also heard that since it is hicas and my s13 is not then it wont.
If I can not bolt up the entire subframe then will the hubs and brakes with the drum handbrake assembly work using my spindles or do I have to change the spindles and just have an extra hole (where the hicas rack would be) ? Thanks!!
