r32 subframe on s13!?!
BoostFab
Car: S13cp, S13fb, S14z
has anyone venture into putting in the entire r32 subrame onto the s13....
accel junky
Wow....that looks like it would be a hard job...
Carl H
not hard at all, about as hard as dropping the subframe and reinstalling it.r32 rear subframe bolts right in.if it has hicas on it (which it does as that is a typem subframe) you will need a lock bar so the rear wheels dont go flopping around while driving.
lmnhed
Car: 92' S13 coupe
Is there a benifit to this? Is the r32 subframe stiffer?
BoostFab
lmnhed wrote:Is there a benifit to this? Is the r32 subframe stiffer?
benefit, hmm... the brake system, 5-lugs, 4.3 vlsd--perfect for hight rev rb20's, beefier axles.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
If you are going to do this, it would be a good time to replace those subrame bushings. It will help stiffen things up.
O and I am so jealous. I was considering doing the same thing but I never found a cheap enough setup to make it worth doing.
themadscientist
A lot of people go for the S15 subframe, it may be even stiffer.
BoostFab
NISMO_RB25 wrote:If you are going to do this, it would be a good time to replace those subrame bushings. It will help stiffen things up.
absolutely, new bushing will be in order as well.
Carl H
it wont be good on the revs as the stock rear end is but it will be good for impressive acceleration.
Imissmyturbo
Car: Car's, Turbo's, sking
Hmmmm. I have an R32 subframe in my shop here. I used it for the rear end. I always though it wasn't a boltup to the S13. I thought the subframe mounting holes where off an inch or so.
Carl H
that would be the z32 rear subframe.
foCk
the a31 fits right up as well
aimcheater
Car: 240sx
where can someone pick an S15 or R32 subframe up?
BoostFab
aimcheater wrote:where can someone pick an S15 or R32 subframe up?
call venus or jarco
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I bought one from jhot exports compleate for 200 dollars here is there number http://www.jhotexports.com JHOT Exports1530-1D Crescent CourtAugusta, GA 30909Office telephone: 706-364-6446
