r32 spindles?
redrockets13
Car: 1990 240sx rb20 11.5psi
i bought a r32 front clip and ive done the swap a month ago and was curious if i could use the r32 5 lug spindles. if anyone has any sugestion it would be gratefully appreciated, thanks
SmithSR
Car: 240sx
The fronts are not interchangeable. Suspension and cast knuckles are similar to Z32.
redrockets13
thanks for the help. so are u sayin i could use some of the front suspension?
SmithSR
Car: 240sx
No, but the rear subframe and suspension will have many useful items..
Good luck!
Phil...
McRussellPants
Car: 92 240SX
The Front Lower Control Arms and the Tension Rods are the same. But its unimportant since they are the exact same as stock S13 stuff.
The S14/R33 FLCAs are the ones you want... they are about 10mm longer and all you'll have to do is press in S13/R32/Z32 balljoints. (or use the S14 spindle)
Even the R32 Rear end is pretty useless since everythings the same. the S14/S15 you can wedge on to the S13, or use eccentric subframe bushings. S14/S15 subframes are slightly wider, less squat and are stronger than S13 subframes
