R32 Skyline stalls while driving
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
bigsiskylinenz
Hey guys just brought this skyline and most of the time it goes very well but occasionaly it stalls or loses all power and depressing accelerator does not help I have noticed at this time it seems to lose most of its oil pressure I was hoping someone could help. Thanks
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
well, losing oil pressure just as it's stalling, or a result of the stalling?
If the oil pressure loss is what is making the car stall, I would cease driving it immediately, and replace the oil pump, and oil pump chain, and the sprocket too if it shows signs of wear....Maybe the chain tensioner has moved or been destroyed? (replace that too!)
themadscientist
RB does not have a chain anywhere. The oil pump is driven by an eccentric gear on the crank. You are losing oil pressure because the engine stalls and stops turning the pump. Could be a bad air flow meter.
Ozzie
'06 MK5 Golf tdi
"Ahhh, I see" said the blind man, to his deaf dog.
themadscientist
huh? Are you nipping at the Simple Green again Oz?
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I had a Problem like that and it was CAS (Crank Angle Sensor) going bad but it could also be a bad MAF. or Electrcal problem.
Return to “GTR Forum / Skyline Forum”
