Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed Dec 26, 2007 6:50 am
You might want to do a full fluid swap while you are at it. A lot of "softness" is from the fluid absorbing moisture over the years.
Layla was one of the first 1994 Q's, with a February 1993 build date. Her brakes stopped a LOT better than the Lola, who is a late 1994 build, with a build date of November 1994. Layla was almost twitchy on the brakes, where Lola seemed a bit more sluggish.
The Z32 calipers and larger rotors helped, and the ss lines helped some more, and the DOT4 fluid helped even more, but Lola still does not stop as good as Layla did. I bought a master cylinder from a 1990 Q that I plan to swap out. I have heard on here, that the early 1990 master cylinders were better than the later ones.
I also intend to flush the brake fluid again.
