R32ONP »
https://forums.nicoclub.com/r32onp-u163432.html
Sun Jun 27, 2010 10:12 pm
howsit guys iv got a factory RB25DE auto R32 GTS25..its stock as a rock.....it starts fine wen cold...but wen its up2 temp its hard to start..and after a thrashing its harder to start..once it starts it runs beutiful no problems wat so ever...but wat it does wen hot is it starts cranking then it bogs the starter hard ( sorta sounds like its pulling the timing) then it goes right again then the starter struggles then fine and u sorta get the picture...the ecu is throwing no faults..i have replaced the coolant temp sensor and it still doing same thing..it doesnt use any water or any oil or smoke or anything so is it the starter motor?? but i dont think it is cos the other day i was having real troubles with it trying to start and it was black smoking wilst cranking??? any help would be apreciated as it sux being hard to start wen hot!!!
